1 - 10 of 10 Posts
I just bought a 2005 350 Raptor last week. It has been jetted and the baffle is taken out of the exhaust. I was just wanting to know if the Big Gun Rev Limiter Box would help out with power gains any. I will be 16 next year and am going to be needing money for a truck so I really dont want to buy an exhaust so I was looking for something a little cheaper to improve my power gains. And if you guys know of anything else that is cheap that will help, please tell me, it will be aprreciated. Thanks!
You wont feel the difference.................
you could get a k&n intake for cheap, if you want to spend a little $$ then a hmf slip on but a rev box is usless, you won't feel any difference at all
you don't need to get a full exhaust with the 350, the stock header is really good! (from what i've heard on this forum..) You can get slip ons pretty cheap, and it will definitely make a noticeable difference in performance. As for the rev limiter, it's a waste.. The 350 doesn't have a rev limiter (not sure why Yamaha did that) but buying an aftermarket CDI is going to do absolutely nothing for you..
getting an air filter mounting kit with a k&n, removing the lid, and rejecting the carb would make a huge difference in performance for about the same price as a CDI
Yup, stock header flows plenty for these motors. I noticed a big power increase when I removed the airbox lid, and ran a straight pipe.
By straight pipe you mean the baffle taken out or getting a new slip-on?
Spend the money on things that WILL make a difference - an aftermarket CDI won't unless you've built the engine to the point that peak power has raised significantly in RPM... and you haven't.
Open the exhaust and the intake and re-jet to match - this you WILL notice.
Actually on our 93 Warrior, the CDI did help the performance noticably, and even more after all the work we did to it....................:)
But whether it was worth the money, that is a good question..............
1 - 10 of 10 Posts
