Banned
Ok i installed the 2nd dynatek unit, and it ran ok, still with a small mis here and there, but better than yesterdays box, i let it warm it and the fan cycled on and off, I shut it off, and turned the key back on but it wasn't running, and I moved the kill switch back and forth, and went to start it, and nothing! Its dead to the world,
the fuse it good, i have no neutral light or anything! What happened and why?
I jumped the solenoid and the engine cranked but no start cuz the fuel pump isn't cycling.
please help i have a ride tomorrow.
thanks
craig
What about with the dynatek ing off, will it work then? You might just have to ride without it on and then figure it out later.
Take the Dynatek off and see if it works then. Maybe you have another faulty unit..?
Banned
Discussion Starter #6
figured it out! POS UNIT
When its hooked up it blows the ign fuse every time, when i hook the coil back up stock, then it runs fine and doesn't blow the fuse.
I"M GETTING VERY POED! THIS IS THE 2ND POS LOL.
THANKS
CRAIG
I'M CALLING THEM AND WILL SEE IF THEY WILL JUST SEND ME A PROG UNIT
THANKS
CRAIG
Get your $$$ back and just buy one from DL.......
