I've been talk to HDD and looking around here about going to a bigger throttle body and I'm still a little confused. I know the bigger opening will make more power but then I was hearing that it can have a little bit of a lag. I ride trails and some hill climbs so I think the throttle response should be very quick for me. The build I plan on doing is the 11.5 piston, hc3, and porting. I'm upgrading my HMF to force 4s pretty soon. What do you guys think? Thanks
Dr Dune
You won't have any lag with the +3. I wouldn't recommend the 54mm for the type of riding you do, but the +3 should show benefits across the board.
thanks
I have the +3mm TB also and have had no problems......I didnt notice any lag on the bottom or loss of throttle response. Some say that they have....What type of intake do you run? Definitely nothing bigger you wont have the motor for it!
With the build you are talking about it should have like 60-65hp but I am sure a builder will chime in.:D
I have a pro design with a amsoil filter. I can't use a k&n filter where I ride the coal dust goes right though so the fci is out.
8SEVENTY3
A +3 is a mild but beneficial modification...I don't see in any case where a +3 would be too big. You shouldn't notice any lag but you should notice a stronger pull, especially paired with some motor modifications.
Ok thats good to know.
When swapping to a +3 is it necessary to get the fuel controller re mapped? Im sure for optimal gains it would be, but just to run?
