I just got done installing my new X-Bars with the mount for my vapor and my billet gas cap wont work. It hits where the key mounts to the Trail Tech bracket. Anyone running a Billet Gas cap with theres that will clear the key. Thanks
The bottom piece comes all assembled if you turn it around it wont work, not sure exactly what you mean. Here is there picTimelessR1 said:Not to put a damper on your installation skills , but i think you mounted the bottom part of the bar adaptor in reverse. The key isnt suppose to be close to you. It should be in front of the hadle bars.
I almost did the same thing, except i dindt have enough slack on the ignition wires so it made me think about which way the key was facing originally.
It might but the dash already has a raise on it so that would bring it off the stem pretty far and I like the height of the bars. I can get the gas cap on and off by turning the bars to the side but it rubs when you square it up. Im going to see about shaving it down a little and see if it will clear.Maddog56 said:Would this do the job? Maybe lift the bracket above the level of the cap? Might still have a tough time getting it on and off though.
http://www.rockymountainatv.com/pro...&vehicleType=&pageLinkUri=&prodFamilyId=12976
I drilled all the rivets out and then just put new rivets in all the holes :thumbsup:skidoo said:bberck how did u get ur saftey sticker thing of the left side with out takeing out the pop rivits ?
It was a easy install its just my billet gas cap is about 1 inch bigger around than the stock gas cap so it hits. It works fine with the stock cap. I just need to find a billet cap that is the same diameter as the stock cap.blueyamaha said:well...
Is there any other brands of computers out there that i dont know of? I like the set up of the raptor handle bar clamps and the trail tech computer. But i want a setup that is easy to instal not a pain in the ass.
Not really.. Its not bad to install.. and if you do the DR. D reverse re-locator with it, its a very nice setup.. Nice to have reverse right by your thumb anyways.. just unscrew the key, re-route to reverse location and you are good to go.. takes a little time, but i wouldnt call it "hard to install"blueyamaha said:well...
Thats all you need, just make sure you get the right dashboard. They make a 7/8 and a 1 1/8 :thumbsup:blackraptor said:Can someone tell me what should be included in the kit for tag t2 handlebar? vapor computer, dashbord and what else?
