hi, I have a problem with my 2004 Yamaha raptor 660r it starts up fine and will idle good as I hit the throttle though it starts to pop, starts sputtering and also it backfires with flames coming out of the exhaust almost every time but when I hold the clutch it revs just fine, until I pop it in to first gear it will just bog down again and sputter, I bought some carbruators of ebay hopping that was the problem but it basically just made it worse, please help if you know what might be the problem
Welcome to the forum!
Unplug the parking brake switch and check the reverse switch.
Look at #2 here:
Discussion Starter #3
Look at #2 here:
Ok I'll try that I hope that's the problem
Discussion Starter #4
Look at #2 here:
Look at #2 here:
Ok I now unplugged the PB sensor and it revs good again in neutral without backfiring problems, but as I put it in to first gear it will start backfiring and sputter I can only get the throttle to about 1/4 before It shuts of again because of bogging, would that be a carb or an electrical problem.
Thanks
Most likely carb cleaning time...
I'd check the reverse switch as mentioned above. Reverse has a rev limiter and if the bike thinks it is in reverse it will cause the symptoms you have.
