Got a couple presents in the mail today, one box from RMATV and the other from Quadpartsguy. I now have the ASR a-arms (which look to be of very good quality), stainless brake lines, and a couple other nick nack things. I got the pro star that is only camber adjustable, I didn't want all those extra heims.
The only thing bothering me is all the little washers and bolts that are left after I'm getting closer to getting it all together. :eek: :crazy: :unsure:
But anyways, I'm trying to bleed the rear brake line but It just won't purge. I cracked open the rear banjo and I've been cranking away on the brake pedal for 10 minutes and nothing but bubbles... what am I doing wrong?
The instructions tell me to loosen the bottom banjo and pump the brakes untill fluid comes out, then tighten the banjo and then loosen the bleeder screw until fluid comes out.
Is that the correct process?
dont loosen the banjo bolt
heres what you do
fill up reservoir with clean brake fluid from a sealed container
pump break pedal with bleeder screw and banjo bolt tightend
hold brake pedal down and open bleeder screw once pedal is at the bottom tightend bleeder screw
reapeat until no more bubble come out ;)
