It seems I have lost most of my rear brake pedal??? I push it down the whole way and barely get any brake, what do I do to adjust this, I havent checked fluid level yet but im sure its not low and I had rear brakes last week. Also its getting about 10 F here, does that have any effect because right now they are sucking :(
There is a recall for 03's (I think), and perhaps others, related to vibration causing air bubbles to get sucked into the rear master cylinder. They add some rubber grommets in the mounting holes to reduce the vibration coupled into the reservoir, eliminating the cause of the bubbles.
