Go to Homedepot and tell them that and they'll hook you up with a drill bit and reverse thread extractor
The UK's fastest Raptor
if if broke 'cos you did it up too tight then an easy out will work like a charm. If it broke because the thread is ceized and you then over tightened it, then and Easy out might not be so successful. Hope it's the first one. From experience I would always recommend expensive Easy outs such as Dormer or Snap-on.
Good luck
Ez
yeah, it'll probably be the smallest in the set, my smallest requires a 5/64 drill. I was using it to get a skid plate bolt out yesterday from a swing arm I got off e-bay.:)
