mdnt said:personally had best luck with Left twist (reverse twist) drill bits... hard to find but sometimes the drill bit will catch and yank it right out as ur drilling it![]()
Both of these are right!bgmac said:You should be able to find them at your local hardware store. You have to drill a hole in the screw first, then you use the reverse drill bit to back it out.
