iam buying a hmf sport slip on and wanted to know if you need the dobec comp. and if so what settings would i need to set it if any????
You should get the Dobeck because if you don't you will end up running lean and you could damage the engine.
i have a hmf slip-on, i have the power commander. i tried riding it down the street before i put the pc on but it ran like crap. in my situation it was needed. some people have run just slip-ons without controllers and i have been fine. just keep an eye on the plug.
is the power commander tru hmf or is it tru someone else??
through some1 else......you have the dyno jet programmer and a dobeck tfi controller, if you dont plan on gettn serious with mods a dobeck is fine, if you plan on building ur motor you need a pc
If you have a good Yamaha dealer around, he should be able to adjust the existing controller so it will be fine with the HMF, most don't know it, but my dealer did, and mine runs great.
