will just changing the cam help out with power or do i have to do other stuff to get the full effects of the cam? which cam? thanks!
Cam is a good start, porting will make a difference also, opening the airbox will help lots.....
If you dont want to do any head work or change your valves and springs then just get a stage 1. It should give you a bit of a performance boost. Im with willykiller though if you wanna get the most out of it. =)
how much work does changing to a stage 1 cam involve?
Instaling a cam is relatively easy. Im sure if you do a search you will find a write up someone has already done on how to do it. Check the manual that you can download. Good luck=)
Ok will do thanks for the info!
No problem. Let me know how it turns out.=)
