1 - 12 of 12 Posts
all specs @valve with .040 lift
Stock 700 rappy
lift duration
in. 386 237
ex. 347 235
Megacycle x1
lift duration
in. 420 246
ex. 385 244
The X2
in. 480 264
ex. 445 260
Hot cams stage 1
in. 378 253.5
ex. 339 243
Hoy cams stage 2 So pretty much the only difference between stage 1 and 2 hot cams is that
there is more intake valve lift on a stage 2 that's it.
in. 405 253.5
ex. 339 243
look better? I was in a hurry crusing the net between classes ::)
You didnt put the secs for web cams. So which would I benefit more from with a 11.1 piston and duals? I need to read up a little more on cams I know.
hey sparky have you guys tested the X2 Vs. the web cam stage 3? and do you know the specs on the web cam stage 3?
I would be instrested in that too.
Yeah, I would also be intrested, I was looking into buying this http://www.duncanracing.com/prods/DR-294K/ but I don't think I need the head porting and seating for $500, I'm pretty sure I can do that myself, I mean I port snowmobile jugs all the time, but I don't know, is it worth the $500 to get it professionaly done? I think the only difference is, one person is getting paid and the other isn't. :thumbsup:
Im not sure, but i dont think you can do valve seat at home can you? Port and polish im sure you can probley do a decient job. Maybe the same if your good and know how much and what to take off.
I still dont see why you would want to spend 1000.00 for a cam, springs, and valves. Anywhere else its a lil more then half that. Says on the site with porting (which would bring the total to 1500.00) you can expect a gain of 5hp. I dont think thats anything to brag about for 1500.00 do you?
http://www.geisickperformance.com/yamaha_raptor_700_cams.htm
flybyraptor, you are the man!!! That is what I have been looking for. Thanks.
From what I understand hotcams says that you do not need to do any valve springs with their cams they are "drop in"
Does anybody have a desktop dyno? I would like to see how the cams differ from one another "theoretically"
Ok yeah I think I will hand it over to the pros. I have all the equipment (except for flow bench) to do it but I don't want to mess it up. Any ideas where I can get the seating and porting done for a good price?
check with site sponsors, they are usually willing to work with you!
I know I have been talking to Geisick performance and it will run 450-500 for the port and valve seats for +1mm valves!
1 - 12 of 12 Posts
