Hotcams give their specs away, but is this the physical spec of the camshaft? The rocker shaft and rockers on top of the camshaft seems to have a ratio of 1:1.6 on the inlet and 1:1.2 on the exhaust. So you need to take the camshaft lift and times it by the above ratio? Is this accounted for in the spec sheet of the camshafts or not?
