im getting ready to put on new bars and was thinking about getting rid of the key. The bike is always locked in the garage and i would bet if someone steals it they wont be starting it up anyway. I know I can move the key somewhere else but i would rather just get rid of it. Is it even possible? i removed keys before on 2 stroke atvs, but they had no battery. Thanks in advance :cool:
If you are keeping the stock steering stem you can get a trail tech bar clamp that has a place for the key.
The only issue I found was the wiring is not long enough to fit I had to add about 2in of wire to get it to fit.
The trail tech clamp is a nice bit of kit.
Removing the key would be easy it is only two wires. You could use a toggle switch or something similar.
What if i didnt use a toggle? Would it kill the battery even if the kill switch is off?
yes the kill switch just interupts the spark. u need a way to switch the batt power on and off. i guess u could disconect the batt every time you stop and then hook it back up to start the quad again. a key just makes life alot easier. J
ok well i kept the key. i just ziptied it down under the bars in front of the radiator. it looks alright. i will have to ride it and make sure it stays.
I installed a switch on mine this weekend after loosing my key. I simply spliced the wires and installed a switch between the two. The key would still work if I find it and the switch bypasses it. No issues, works great.
Funny thing is that I called the dealer to get a new key... and he told me I needed my key to make a double. Talk about having things backwards... Apparently Yamaha does not have a database of key models vs serials.
tech quad shop has the billet key holder that goes in the reverse spot and they work great. I got mine from jokers vault but they are no longer around but I have the Dr D reverse lever that mounts on your hanlde bars. Tahitis key spot is a good one too.
