4mm but make sure you buy smaller ones cause on one side of the bowls there is a lip that will stop long screws from tightening down....
Alba sell some good one for the bowls. but i dont know the sizes.
take the old screw in and match it. If you dont have the old screws, take one out of the throttle cover. The throttle cover screws are the same thread size, but are shorter in length. Be sure to replace the screws on the throttle cover as well. You should get 11 screws in all, 3 shorter screws for the throttle cover and 8 for the carb bowls
I'm pretty sure that they are M4 x 9mm (4mm diameter and 9mm long). You should be able to get those at a hardware store or even better, a fastener store <--- you could probaby get stainless there.
