01 yoshi full open air k&n Vito's jet 25, 155 160 pulls fine get to the top of a dune and like loads up dogs down and dies at low throttl. Tried screws from 1.5 out to 3 no diffrence any suggestions? Thanks
Check float levels.
Where is little sahara in comparison to where you normally ride or is little sahara where you normally ride? The reason I ask is because the difference in altitude may cause you to lean out (sahara is lower in elevation than where you normally ride) , or richen up (Sahara is higher in elevation). Other things to check is float levels as QM said and even dirty carbs. Pull your plug and check its color. Just my 2 cents.
UM no. higher elevation = less dense air. This means you run richer with the same settings. You probably need to lean it out, which is why I say check your plug. I bet its black.
Make sure your carbs are spotless and that the slides,butterfly valve, floats and everything in general is working properly.
