· Registered
I bought a 2005 660 a while back and didn’t realize it had a Chinese carb (first time buyer, just wanted something to tinker on and learn) I bought a OEM mikuni carb and was just wondering if this little needle thing on the float is suppose to move freely or not when seated in that hole and if so what can I do so it will, it just seems to get stuck
Wheel Tire Vehicle Automotive tire Hood
Tire Wheel Vehicle Car Automotive tire
· Administrator
Yes that will be free floating, others more versed can explain better.
Reactions: Sixpack577
· Registered
That is the jet needle(not to be confused with the needle jet, lol, they Are 2 different parts).
The "hole" is the needle seat.
The needle hangs on the float tang, as the float bowls fill, the floats rise, and that needle rises into the seat and shuts off the incoming fuel(basically it's a valve).
Then as the fuel in bowls gets sucked out, the floats and needle lower letting more fuel in, and then it repeats.
The needle should not stick in the seat.
The needle and seats are one of the most common fail points in all motorcycle/atv carbs, they wear and can no longer seal properly. Then you get fuel running out of the overflow tubes, as the needle and seat can't shut of the fuel completely, and the bowls flood/overfill, so it runs out the overflow.
The only fix would be to buy a quality carb rebuild kit and use the needles and seats out of them(which are the Only parts other than o-rings and bowl gaskets that you should ever use out of a rebuild kit. Never use the jets or needle jets out of them, as they are rarely precision enough to work correctly, and they'll keep you running in circles trying to tune them).
· Registered
The pilot and main jet sizes will vary by any modifications.
If you want real power and throttle response from a 660, remove the airbox lid, you'll need an air filter adapter, as the filter attaches to the lid.
Then, two #25 pilot jets(stock is 22.5)
Get a DynoJet jet kit(no pilots are included)
It has 2 needle jets with a different taper than stock, and 6 grooves for adjustment, vs the stock 5. These are Only available in the kit.
If you have an aftermarket exhaust, you will use the 2 largest, or 2 second to largest main jets in the kit. The right carb main jet will Always be one size larger than the left, no matter what.
ALL other carb settings will be the Same, Always.
Start with both fuel screws at 2 turns counter clockwise, then adjust in 8th turns to dial in.
Vitos fuel screws make adjusting them so much easier.
Look in the Stickies for the 3mm clear tube method, this is the Only way to correctly set float height.
Set the floats between 13mm and 15mm, then put them on, and clear tubes off the float bowls.
The fuel levels should be even with the line where the float bowl meets the carb bodies.
This is a tedious adjustment, and can take several tries to get right, but is well worth doing.
You can also trim the float stops so they rise a little higher, and allow more fuel into the bowls.
This prevents fuel starvation at high rpms, it harms nothing to do this, but is usually only beneficial on highly modified engines.
I've done several 660's this way, and it makes a very noticeable difference in throttle response and performance.
There's alot of info on it all here, and there's a few of us still here that can help you with it.
Ask questions if you need to, and good luck with it.
Also, if you do remove the airbox lid, you will need a small autoparts store k&n style round filter to go on the end of the crankcase vent hose, as the hose normally connects to the lid.
A filter skin is a good idea too
Motor vehicle Automotive fuel system Gas Coil Auto part
Art Tints and shades Automotive lighting Space Font
Rectangle Font Handwriting Tin Carbonated soft drinks
Land vehicle Vehicle Automotive lighting Motor vehicle Automotive tire
Bicycle tire Motor vehicle Automotive tire Bicycle handlebar Wood
· Registered
View attachment 144126 View attachment 144127 View attachment 144128 View attachment 144129 View attachment 144130
Wow man thank you for the information, I almost just ended up selling it as is and trying to find something fuel injected but will order the parts and get back to work!
· Registered
Also what carb rebuild kit would you recommend?
