1 - 2 of 2 Posts
Bike has full HMF
No air lid with foam filter
48 pilot
178 main
problem is under throttle sounds like it is hitting rev limiter. just purchased bike and as soon as I went to ride it this occurred. Looks like the starter jet is supplying fuel at all times. Anyone had this problem before?
Your jetting (in my experience) is too rich. It will hit a rev limiter in neutral or when it thinks the parking brake is engaged. Pb rev limiter is an issue on most of Yamaha bikes.
Your jetting assuming stock head should be closer to a 168 main and 45 pilot. I also run the needle out of the yz (ncvq I think) one notch rich of center.
1 - 2 of 2 Posts
