It was 14mm.on that last picture what is the measurement taken? Because I see your using a caliper to measure.
That is a blurry photo, but that's not 3mm, more like 300mmThis is mine pulling it out to 3mm. Doesn’t even look close to your bowl. End when I adjust the tang down that much it basically has no play.
Yeah, you're reading the scale wrong.that’s the issue we’re at right now. I’m using a regular size ruler that inches on one side and mm on the other. From your picture with the caliper that looks a lot less than 3mm on the ruler I have. And my floats looks way out more than yours.
Maybe didn’t push them in all the way? Figured once I could screw it in would be good. I did have to tap them lightly into place. Pretty sure the feelers don’t go that low.Yes, those feeler gages will work.
You'll need .003 to .007
You Need to recheck needles and seats if one carb is leaking
Only You know the answer to that.Maybe didn’t push them in all the way? Figured once I could screw it in would be good. I did have to tap them lightly into place. Pretty sure the feelers don’t go that low.
Yep, I've been doing this a long time, go by the service manuals, pay close attention to details...and sometimes I Still screw up something that I have to go back, find, fix, and wonder how the heck I missed that.even after rebuild she’s always fired up first start no issues. Before waiting on the boots I literally had it all apart changed all the orings. Cleaned and blew air threw. And put it in a ziplock until the boots got here. Has to be carb related because the mikuni is the only thing I’ve changed. Even with the cheapo carb fired right up and everything worked electrical wise.
