301 - 309 of 309 Posts
Hi,
I have a problem with my 660 it idles fine with choke open but when i ride it it bogs is this something with the idle screw or does the carb need to be cleaned.
thankyou
Look at "Another carb question". A current thread, with your question answered.
I turned the mix screws on my carb out only one turn and it seems to be running just fine. Does anyone think I should reset them out to three turns? Thought I might run into trouble when the weather gets cold. Is there any way to adjust them while still on quad. Can't seem to get in there to well with a short screwdriver.
Id recommend these:
http://www.ebay.com/ulk/itm/291610304687
They are offered in various colors. Here's a pic of them installed on my carbs. They're able to be adjusted easily with long-nose pliers.
i just read this whole thing! alt 1200 ft. 02 raptor fmf powercore with header no lid and k and n. fmf recommends stock pilots and needles 145/150 should i go to 150/155 and 125 but what of the needles and what settings and is it cheaper to peice meal a kit to gether or get a kit
2001 raptor 660 k&n drop in filter no resonator on stock exhaust holes in lid
Cincinnati Ohio location
I have a DJ kit what main jets should I use
I have put in 25 pilots also
I have the same ATV
I run stock lid, snorkel removed.
#25 pilots, Mikuni 150 left, 155 right.
Extended fuel screws @ 1-3/4 to 2 turns out.
I would cover ur holes in lid and remove the snorkel in front of the airbox lid, and run the DJ equivalent of Mikuni 150 & 155 mains.
It will open ur eyes!
I also have aftermarket needles set in 4th slot down from the top notch.
Ur altitude is the same as mine.
Hope this works for ya!
