is there a certian grease u use for the carrier bearings? just took mine apart today and my carrier is more than likely shot. ordered another one from tqs today and just wondering when i get the new one what kind of grease to use just the standered lithium soap grease or bearing grease?
The UK's fastest Raptor
are you getting a carrier with a grease zerk or are you going to remove the bearing seals and put the new grease in the re-fit the seals?
I use Mobil XHP222, it's a bearing grease designed for marine and agricultural use, so it's about the most waterproof grease on the market.
yeah its a zerked carrier now ive seen the ones on tqs and its in the center of the carrier..wouldent that just grease the center rod and not the bearings itself?
you need to remove the seals from the bearings in that case so the grease can get in and out of them. Excess grease can then get out past the lip seals which helps them last 10 times longer.
