coalshedracing posted dyno runs with the dynatek programmeable cdi, with 4 different curves, one was a stock curve...the biggest difference was 1hp and some change between the highest and lowest readings. If you want to run to 10000rpm with a stock rod it won't last long, neither will the case. The dyna's can be programmed to let it rev more freely, but nothing worthy of hp or torque.
