are cdi's worth it i see alot of people dont think thay are, and alot who do?
IMO it's not a worthwhile upgrade for most because the timing change doesn't make a noticeable effect on the low end and the higher rpm limit is well beyond the powerband.
That said if you've done everything else and are looking for that next step a Dyna is still an upgrade from OEM.
The only other real reason I can think of for their use is for a tach output, but I believe Dyna is the only one with that feature. That or a cheap oem replacement, but OEM can be found rather cheaply sometimes online.
i have got a cdi box, the only things i have done is in my signature, could i run mine without a problem, or should i worry about a rod going through my cylinder head.
what kind of cdi do you have 05 rappy? and was it worth the money? i would just like to incress the rpms.
