1 - 20 of 21 Posts
what is the main difference between the stock cdi and the after market? and if you change it is there any benefit on a stock engine? and if you change it do you have to do anything else? thanks
There is no benefit from an aftermarket CDI, unless you have extensive engine mods............
ok thats what i needed to know thanks bud
The only benefits you would probably see are rev limiter removed and reverse limiter removed. Probably not beneficial in most cases. However I do have an aftermarket 01 CDI if you wanted to buy one.
I bought a Big Gun Over Rev CDI and it put a rev limiter on reverse so bad that I coudlnt even go in reverse. Barley hit the gas and it would bog down. So i removed it. I would like to re install it if I could have a normal reverse.
maxtrax what kind of CDI do you have?
mine hauls ass in reverse and whats to flip over
Do you have a Big Gun CDI? Mine with the stock CDI has a reverse thats way too fast. I was told its b/c its a 01 trans.
no mine is all stock to my knowledge
i know its so fast i just keep clutching it i am scared to let all the way out the bitch my flip me over! lol
Not sure the brand. It was in a raptor when I bought it and the guy had purchased it brand new. He had some other electrical issues and thought it was the CDI. I used it only long enough to test its functionality.
Edit: I did some checking and it is a Rick's CDI. PM me if you are interested and I can cut you a good deal on it.
yea i am waiting on tax time i am gonna get some itp wheels and tires
Discussion Starter · #14 ·
i was thinking about changing front and rear sprockets to top end and adding nitrous!
Yeah maybe you can rig up fuel injection too....
Early 01's had no reverse RPM limiter... if it worries you just stay off the throttle in reverse!
Never heard of a Ricks CDI. Does it have a tach output?
Dyna and Vortex are the only ones I know of with a tach output.
Rick's might be Ricky Stator? In which case I think it's a re-labeled Pro-Com box.
When I said Rick's I did mean Ricky Stator.
Ok so it's not a CDI then? What benifits will I get from a stator?
1 - 20 of 21 Posts
