I did a little search for this but......can anyone let me know pros and cons on both?
Are they worth it? CFM claims a 20 degree decrease in oil temp? Anyone have either and can speak on it? Heard of a couple getting leaks over time......
Oh and its for a trail bike so no big build or anything. :D
Blue Lighting has a CFM in the mail, he should post here shortly. He will probably be able to tell you the pros (and cons :\) soon. If it's actually 20 degrees that would be awesome but I can't really see that happening... I know that CFM protects against leaks. If it leaks your supposed to send it back to them and they either re weld or give you a new one, I forgot...
Just a 78HP trail bike
the CFM oil tank holds about 3/4 of a qt more than the UM. I've seen both and like the CFM better.
YOU WISH
:beer: It's the name that sold it to me ;) CFM are cool people if you have trouble they will bend over backwards for you. I will tell you all about it soon!
Cola Crew
The rubber that the tank sits down in the frame on rubbed an slot in the drain plug area it did not leak but I will have to get it fixed before it gose back on.. oh I could not put my Sparks BCX6 on with out removing it so I went back to stock...
