my chain keeps coming loose, and the rear sprocket hub moves on the axle,
i always have to re-tighten before each ride and its soon lose again.
now i went out with someone new the other day, and hes looked at mine and said that the chain is rubbing a hole in the left hand side DMC(as sat on it) just back from the front sprocket.
the quad is a 2007, with a dura blue+4 axle, R.A.D lock nut, and kenda bear claws,
any ideas or help please:(
thanks Dog86 but they were only changed 8 months ago with "allballs" but i will check to make sure
Yeah some of the aftermarket bearing can be bad. I had pivot works go out on me in a few months. I would check that first though. I usually stand on the pegs and rock side to side and see if there is slop anywhere.
could it be the rear shock is 2 soft
Might be because when the chain is loose it is slapping the exhaust. Find the reason for the chain coming loose and I bet it will fix the rubbing issue.
thanks you two, thats what im trying to do, i know that this is probable that this is just one thing causing all the other issues, just need to find that one thing??:(
