either you did something wrong installing it, or your cable is not adjusted tight enough to release the clutch. adjust up right until the clutch lever on the case has no play(dont preload it any) and try that
When I put the bike in gear and start it it jumps like it wants to go but kills, in neautral it will idle fine until I put it in gear, any suggestions?
Did you time the lever on the clutch shaft to the mark on the clutch housing when install the clutch housing.............:)
