1 - 20 of 23 Posts
The choke on my 350 doesn't stay out. It's kind of annoying because it takes two hands to start it. What piece makes the choke stick? I probably need one of those.
On a Raptor 350? Mine is cable operated. If yours is not cable operated, then I would say some parts are missing, or you have an earlier carb. Got any pictures of the carb and the choke area?
I'll get some soon, I was watching this video, and when he went to start it, he pushed his choke out a bit and it stayed in place. When I push my choke out it flicks right back to the right in the off position.
Sounds like the choke plunger in the carb is maybe frozen and the return spring is pulling your lever back. I worked on a Raptor 660 that was that way. That plunger if frozen is a pain to work loose.
Where is that plunger in the carb? I'll have it off as soon as I get my jets so I wanna see if I could fix that while my bike is disassembled
There is a spring behind the elbow where the cable goes into the carb, check that one, and the one in the handlebar assembly aswell.
I have never been into the handle bar part on mine. I would bet the problem is with that spring. Especially since it sounds like the choke is working. On the 660 I worked on, the choke was stuck. I think cable stretching was what made it seem to pull back.
The choke works, it just doesn't stay out. I'll post a video in a few minutes.
Here we go:
Wow!! Something is missing or broken for sure. Mine stays wherever you put it and won't move till I move it. Should be pretty easy to disassemble that whole cable/controller setup and clean and inspect while you have the carb off.
What should I be looking for when everything is disassembled? Should I check that plunger?
Well I can't seem to find a parts breakdown of the lever assembly on the handlebars. Not sure what is inside it so don't have an answer for you.
Alright, I'll take it apart and see.
Found it and it is pretty simple. I would say it is probably on the carb end of the cable. It is number 19-24 in the # 18 box in the blow up:
Choke lever
Discussion Starter · #17 ·
Alright, thanks, i'll take a look at it.
I know this is an old thread but does anyone know what the fix was.
I have the same thing on mine, like there's too much tension on the spring.
Hi! Had the same problem, just use a little thicker washer under the lever screw, and the operation will have more friction = the arm stays in position.
1 - 20 of 23 Posts
