Anyone else use RTV instead of a gasket on the clutch cover? Put a new clutch in, and poked a hole in the new gasket. Couldn't find a new gasket locally so I used Ultra Grey Permetex in place of the gasket. So far so good after several hours.
The Moose Rider
Yes and its been about a year with no problems.
Discussion Starter #4
If you've done this with success, what kind of RTV did you use. I used the Permetex Ultra Gray which is a gasket maker thats highly resistant to oil.
#327 "After Hours"
That'll be fine. I've worked wonders with Permatex. lol
The Moose Rider
I used permetex copper. Its there highest temp rtv. Same sealant that is used to seal up exhaust. I happen to have some of it so thats what I used. Any rtv is going to be resistance to oil. It's non rtv silicon sealant you ant to stay away from.
The only problem with RTV is that when it squeezes into the oil filled area, eventually some can break off and plug small oil passages... The Permatex types that become harder are less prone to this - I'd avoid standard RTV's (i.e. silicone sealant) and use either the hardening types made for oil, as said above, or use something like Yamabond or equivalent.
I use ThreeBond (its just like Yamabond) for my head cover & cases.
