1 - 2 of 2 Posts
Hello, I bought a 2004 raptor 660 and it needed a new clutch. When I bought it the clutch would work but after letting out the lever it would not stop spinning after pulling the lever back in. Now I have put the new clutch in, (I’ve had it apart twice now to make sure all the plates were in the right position) it will run through the gears but it is grinding and there’s a clicking noise coming from the clutch (not the engine). Also when pulling in the lever and rolling the quad backwards it catches, not completely but enough that you have to force it backwards when it should just roll freely. Any help is appreciated. I have pictures and videos so let me know what you need. Thank you
Did you soak the fibers in oil over night?
How many fibers and plated did you install? Some kits come with extras to replace half fibers.
How much free play do you have on the clutch lever on the case?
WELCOME TO THE FORUM.
1 - 2 of 2 Posts
