1 - 2 of 2 Posts
Hi installed a new clutch an heavier tension springs but now I have zero slack an can not get the clutch cable in the bracket ugh :-( I did rotate the pivot lever once or twice clock wise bc I couldnt gain any tension before hand on the lever. I'm sure I need some slack please help me get this right.
Thanks
Charles
Thanks
Charles
Line up the timing marks on the clutch lever to the clutch housing, it should be lined up when the lever is rotated clockwise and should be practically pointing away from you as you look at it or in another way to say it, it should be at 9.00 oclock with twelve oclock being the front of the bike.........:)
1 - 2 of 2 Posts
