when i pull the clutch in with it still in gear it wants to move a little its on a 660 raptor should i tighten up the cable more ?
If the engine is cold, it will do this until oil warms up................:)
Normal cold operation.
what else is normal cold operation?? WHen you start it up and try to ride it... it loses power when you pull the clutch out and you have to rev it up higher to move...
Please start a new thread with a lot more detail about your symptoms.
BTW, you PULL the clutch IN to disengage, you LET the clutch OUT to engage.
