Hello guys, :help:
During the weekend I changed my chain, my sprockets, removed my parking break and changed the clutch lever. Now here is my problem, when I removed the parking break I broke the little sensor that was on the lever by accident. I don't know if there is a limiter that engages or something, but Now I can't adjust my clutch properly. Every time that I put it in first gear the quad starts to roll even when I have the clutch held down. When the engine is running I am able to change gears but can't put it neutral. I tried to adjust the clutch cable I put it to the max adjustment. I even changed the adjustment screw, put a longer one to have more adjustment. That did not work so I am running out of ideas. I also changed the location hoping that it would be the problem. Could it be the part that is not good. I put a Magnum clutch lever, is it supposed to fit on a raptor 660?
