Bike not running in first gear but still rolls as if in neutral.After messing with it for a couple of seconds in goes in first and runs as if nothing happen.Only to do it again the next time.
We are definitely going to need more info. Adjust your clutch either at the perch or by the brake lever. Does it run in all other gears? Will it go into neutral?
OK first of all the bike runs fine it starts everything other then the clutch is fine.It does go into neutral and the light comes one.
Now for the clutch it has some problem with the first gear.It only acts up sometimes.And other times it fine.It acts up by not going it to first as if it has two neutrals.
Sometimes from first to second it's a little harder to lift lift the gear up,but it eventually goes in.
Also for example when I have it turned off and in first you can roll it as if its in neutrel.(but it does start its just turned off)
Mines been doing the same thing i was told my clutch went. I dunno whats wrong with it.
