what does it feel like when clutch slips, does it feel like ur chain is slipping on the sproket kinda thing or is that my trannny gears, im using canadian tire synthetic performance atv oil, may be a problem aswell what u sudgest i do, put yamahlube in it then see if i still have weird slipage? or ring it in and get tranny replaced?
If it slipped, it is not the tranny. You'll know when the tranny goes bad. I am not sure about tha canadian tire stuff. I always use yamaha products ( oil). You can try to adjust your clutch at your lever or right by the clutch arm.
When riding, go on 4th or 5th gear at half speed and just give her. If you hear your idle go higher and you don't go faster, it is your clutch.
A bad clutch will slip just like if you tried riding without letting the clutch all the way out, there won't be any jerking or stammering like when a chain slips on the sprocket.
