Clutch replacement is fairly straight forward. If you follow the manual step by step you should do fine. Here is a tip- soak the friction plates in oil overnight before you install. If you burned one up in one year I would look into a Hinson clutch. I ALWAYS put Hinson on my dirtbikes, and I probably will on the Raptor when it wears out. :thumbsup:
