1 - 2 of 2 Posts
I recently bought an 03 raptor. when driving it it seems like there is a little hesitation after i shift gears, I don't know if it is with the clutch and it needs adjustment or replaced. Do any of you what what this is or how to tell if i need to replace the clutch?
There is adjustment at the clutch lever and on the throttle side of the cases above the clutch housing. If tweaking these does not fix the problem it may be time to take her apart and have a look.
I thought I was down on power a bit but I wasn't experiencing bad slippage. Took it apart and two of the clutch plates had broken into a few dozen pieces.
1 - 2 of 2 Posts
