1 - 13 of 13 Posts
Hi
im taking my quad apart for some winter maintenance, over the next couple of weeks, and thinking of changing the clutch. the reason is that if im in any gear 1/4 throttle and i open her right up, the engine seems to rev really quickly, but the quad is "slow" to pick up, its almost like the cluch is slipping.
so my questions are,
who makes a good clutch? (i appantantly have a modified cluch already with the thicker cluch plate?).
what oil should i use, semi syn, of fully, would this make a diference?
i found this?
http://www.ebay.co.uk/itm/YAMAHA-RAPTOR-700-HEAVY-DUTY-CLUTCH-KIT-/290599252469
the quad has DMCs, GYTR intake and filter, mo-flow lid, PC3, and dyna tech ignition, i am not going to do any internal engine mods.
thanks in advance
I am currently running the EBC clutch, it has been fine this whole season. However, most guys will reccomend the OEM clutch.
i forgot to say that i "belive" its a GYTR if this helps:confused:
ttt:(
Ridin High.....
EBC springs suck Ass. go with oem fibers (8 with clutch mod). Get some HD springs from tqs or HDD. I think dl sells an entire rebuild kit. Or you can shim your current springs with washers if u want. This is from personal experience and opinon. Have fun! Raptor clutchs are a blast to change...
I would go with the OEM fibers and stay with the stock springs.....you don't need the stiffer springs with your power, all it will do is tire out your hand faster. just my .02
Ridin High.....
meh. or dont have little girl hands.
thansk for the advice guys, where is the best place to get a cluch from???
any links please:)
Just throw in an oem clutch full fiber mod and HD springs from HDD buy it all thru them
(951) 743-6328
Ask for Daniel west coast time zone so take into account when you you call.
It's clutch I'm running in my bike holds up fine.
ok update, i have ordered a new clutch from HDD (really helpful guys) is there any tips,hints ect or anything to look out for when i change the clutch, also should i change the cable as well,
thanks in advance:)
Ridin High.....
Clutch cover can be tricky to POP off there's a tab on the right side of the cover I used to pry the cover off with a crow bar. Lining the clutch ARM back up when u reinstall the cover can be tricky as well. Make sure the lever pulls correctly before putting all the cover bolts back on. Good luck!
1 - 13 of 13 Posts
