1 - 15 of 15 Posts
I was reading about the DynoJet Quick Shifter, and was wondering if I could upshift manually without the clutch? If so, is this bad for the tranny or anything?
TIA
I tried to search and didn't see anything. I will try again I guess, and see if that will answer my tranny question.
It's fine to cluchless shift. But I would only do it in high RPM ranges.
Well, I did searching and can't seem to find anything about it. Maybe I am searching the wrong words. Can someone explain how it is possible to do this, is it the cut of the gears? It is bad on the tranny?
It's perfectly fine. The trick is to match the ratios in the trans when shifting. Like when shifting up a gear, put just a little pressure in the shifter and let off the gas... it will go right in, no problem. If u do it right. You can do it down shifting too, except you have to blip the throttle before going down (to bring the rpms of the smaller cog upto speed of the main shaft before engaging it). It sounds more complicated than it is, but it's easy. I rarely use the clutch in anything (even my jap cars).
Be honest, all of the truckers on the road only use to clutch to start and to stop. And they don't even need it to stop!
That's strange...
I could have sworn there were several topics on clutchless upshifts... But now I can't find them either!
Anyway, as I recall, most people agreed that it was fine to upshift without the clutch. Not everyone agreed that downshifting was safe, however... I don't know, I'm just passing on information! 8)
That is true of automotive clutches, but with our bikes it is way easier than that. You have to remember we have a wet clutch in the atv it is not the same as a car or truck.
Just let of the gas and shift. It is a piece of cake and I have never had a problem with my tranny. That is all the quick shifter is doing...
sangue_e_Tripas said:
That's strange...
I for one am not a fan of clutchless Downshifting!
in case you didn't know motorcycles have the most syncronized gear ratios of any motor vehicle,just hammer it wide open,lift to 3/4 throttle and twitch ur big toe on the shifter and hammer the throttle again,you only need to take off some of the pull with the throttle control to switch the gear, i have done it for 20 years on 3 wheelers/street bikes/dirtbikes and now my 700.......... it's night and day difference when you power shift, its kinda like flat shiftin a racecar. 8) 8) 8) 8)
well to down shift it wont really work because your sliders are always engaged in a gear and wont really allow you to do it, you can try to force it but may end up breaking shit,i wouldn't do it, if it was like a car or truck where you have to pass through nuetral it is very attainable but not on any motorcycle,doesent work because due to being constantly meshed you can't rev it while crossing nuetral to match road speed with rpm's for the next lower gear........
1 - 15 of 15 Posts
