1 - 11 of 11 Posts
G
I'm building a type of cold air intake for my Raptor. The only problem I see is that sometimes it will be letting more air in than other times and the jetting will not always be right.
Should I continue with this or quite because of the problem above.
If it's a 700 I don't see what the problem would be there is no jetting, it's fuel injected. If it's a 660 I can't help ya, i'm not familiar with em. But if your gonna do a type of cold air check this link out...http://www.electricsupercharger.com/
Something new to look at if you haven't saw it already.
It works for atv's, I found out about it from a guy that had one installed on his 700.
That thing pulls way too much power for an atv's setup. I think that would fry our stuff.
The electric superchargers are absolute tripe. Do not waste your money.
If you need to know why, go back and take some high school physics. To produce any meaningful boost, a supercharger needs about 100X as much power to drive it than that 12V motor will every produce,
If you are talking a forced air induction like on some sport street bikes, than you may have a lean prob unless the FI computer can adjust for it. I would guess we could pick more power if we could get cooler air into the engine. I think you woudl be OK if you dont have a venturi (funnel) setup on the end of the intake facing forward.
1 - 11 of 11 Posts
