Can anyone explain why your compression would be 100 psi. Even after a perfect leak down test. I would think that it would be about 180 psi with a 12.5:1 piston. :unsure:
no, did not know you had to do that. will that make a drastic diff.
??? :banghead:
YES THEY DO HAVE AUTO DECOMPRESSION.
If I remember correctly a stock 660 was around 180psi w/o decomp, around 130psi w/ decomp.
So the answer to your question is the decompression mechanism.
