G
Guest
·I am thinking about upgrading my 700 motor but I need to know if the stock connecting rod will be good enough to run with a high comp. stock stroke and stock bore motor with cams/piston/valves. Or will I need to upgrade the connecting rod? Also anyone running the rocket factory 734 kit, did you need to upgrade the connecting rod? I am looking into both choices but I don't really want to get in to splitting the case.
