1 - 11 of 11 Posts
I would stay away from the copper head gaskets. They seem to leak if you don't prep them right and almost usually need an oring on the cylinder and even then they leak coolant. I would stick with cometic but the best kind of head gasket is the oem kind.
what about for the guys running lower compression motors...do they still have leaking issues...? also...has anyone tryed to heat the copper gasket up prior to install...say to 200 degrees...then use HD studs and torque to 45 ft/lbs...i would think this should hold well..with the copper being hot and soft and the added tq that it would form alittle better and seal well...just a thought not sure if anyone has tried it...if i had the time and money to play around i would....
03, why go through the bother with a low compression motor?(9.8 stock) Copper gaskets get into whanting toaquire a specific compression ratio dependent on gasket thickness. Copper gaskets should also require, as you mentioned a cylender stud kit for better and higher pre load along with a gasket sealer and o-ringing the head. These applications and setup are generaly beyond the needs of a simple rebuild.
I think o3 was saying that for a racing purpose. If you are running a stock engine there really wouldn't be a need. That is part of the reason for a copper gasket anyway is because they come in different thicknesses and allow you to set the DCR right to the edge.
Cometic MLS gasket. It has a dead soft aluminum ring around the combustion chamber / cylinder.
Discussion Starter #9
i ment the 10.75 low compression, sorry i wasnt clear on that lol. yeah it sounds like ill just stick with the cometic, thanks!!
1 - 11 of 11 Posts
