Does anyone know the compression difference between a CP uncorrected piston compared to a corrected one? I have a 12:1 uncorrected and it sits roughly .050" in the hole. What would the true compression of this piston be without decking the head?
Thanks Bo. That will work out justs right with a +5 stroke for a pump gas build. Does the math hold true if its a 105 bore? And if i decide to up the compression by decking the head then i'll have to adjust the timing to compensate won't i?
OK, by the math.
If you have a corrected deck height 105mm 727 piston thats a true 12:1 at .010" in the hole then if an uncorrected piston is .050" in the hole it will be 10.7:1
If you throw a 5mm crank in it goes to 12.6:1 corrected and 11.2:1 respectfully.
If it was me I would mill the cylinder .040" and have a local automotive machine shop mill half the dome off. This would make more power than leaving it alone with the same octane fuel.
