First off the bike is in a bunch of pieces. Motor is apart getting a +4 getting put in. The head is at a local shop getting what is described as a (trail port) & the center valve guide milled down. I have the 10.75 JE piston, stage 2 cam and valve springs here but where are you guys getting your ferrea valves from???
Stock swingarm is getting the 2 inch extension per the suspension section on the forum.
Just ordered the +2 lsr a arms. 450 shocks already on the bike. Will the stock brake lines work? If not, is it better to get the 2 lines to come off of the brake master cylinder or have the tee at the bottom? My front brakes have never been the greatest. Multiple times bleeding brakes, new pads and so forth. I can never get my front tires to lock up if I need to.
Are any of you guys using aftermarket handlebars? Its hard to look on a website and try to tell how the bends are on them. I'm 5'11" and i'm not lazy when it comes to moving around on the bike.
Any responses will be helpful. Keep up the good work guys!
