CUSTOM TITLE
I installed a cp 102 mm piston and a hotcams stage 3.
I got some pretty good slap noise coming from the piston.
Machine shop said a 102mm would be the right fit.
What is the stock bore size on a 06 700?
is there any other mods i should be doing with this combo ?
A-10 Crew Chief
Stock is 102. Did you check your valve clearances? Make sure they aren't hitting your piston!
CUSTOM TITLE
Yup valves are good .
looks like im gonna pull it back apart and take some measurmets
CUSTOM TITLE
Im also not running an aftermarket EFI controller .
Should i be running one with the stage 3 cam?
