I've spent days looking through old threads and nothing seems to be quite like my problem or if it seems similar there's no solution I've seen. I just got given what I believe is a 2003 raptor 660 which cranks, has good spark and will run off starting fluid. I just replaced the battery and spark plug. I have no idea where to go. I've also gone over the carbs and cleaned the jets. This is what it sounds like. I can post a video of mine later if that will help anything https://youtu.be/Kppp_IY0NIQ
Thanks to anyone who can give me a hand
Welcome to the forum! 1st - you're posted in the 660 suspension forum... I'll see if we can get you moved to 660 general or 660 maintenance - you may not get the visitors you need here.
BTW, charge your battery if you can - it sounds as if it's getting low (cranking speed is a bit slow) to me.
If it runs on starting fluid then you are simply not getting fuel through the carbs.
Have you verified that fuel gets TO the carbs? Do you have flow through the petcock? Open the drain screw on each carb. If fuel streams out, then the carbs have fuel and your issue is inside the carbs - either they are not cleaned well enough, the jetting is way off, or some other issue is going on... how many turns out are your fuel (pilot) screws set to?
If it still is the carbs, check and report back numbers on the jets and tell us what modifications the quad has (exhaust and air box mods)... then it's up to you to figure out since we can't see the carbs. check that both have fuel in them, verify that the fuel screw tips are not broken off in the carb throats, check that all orings and springs and spacers are in the correct orientation on the fuel screws and choke plunger... It should at least try to start and run - does your choke plunger work properly? Are your vacuum diaphragms intact (no tears) and mounted properly? Have you download the (free) service manual yet?
Reactions: Alamo and Mad Dog
Discussion Starter #3
I'm getting fuel to the carbs. I have both pilot screws 3 full turns out. I'm not sure if it has after market jets, it has a high flow air filter and no air box cover with the stock exhaust. Vacuum diaphragms are intact. I will go over the carbs again tomorrow to make sure that it is all lined up correctly. I will test drain screws tomorrow as well. I'm not sure where to find the service manual also, so if you could link that it would be much appreciated
Is your spark plug wet at all? If not then fuel is not making it there and I would keep after the carbs. Have you checked the compression? A hung intake valve can cause a no fuel issue as well.
Reactions: Alamo
