I was on here before and read someone else having the same problem. I have a leak on the bolt that connects the oil line to the crank case. I tried tightening it but it stripped. I'm trying to find a longer bolt to replace it so it can grip more. Does anyone know where I can get one?
Raptor 700?
I assume you’re referring to the return line from the stator cover as the supply to the cases isn’t a bolt. You can get m6-1.0 bolts from most hardware stores. I don’t think there’s much more depth there to thread into. Usually it just takes a new o-ring to stop that leak, sometimes a thicker o-ring is required. You’ll need to do a thread repair or find another stator cover.
If interested, I have side covers for sale. PM for info.
