1 - 11 of 11 Posts
I just got done rejetting my carb and removed the air box lid. I was wondering if i should put a filter on that breather(one that goes into airbox) i don't really know what to do with it. Or just zip tie it up and loop it so it faces towards the ground. Kind of noisy just sitting on the side shooting out air. if i should use filter what size do i need?
This from my 700 but it's about the same it's a evac valve and a filter.
You can run just filter but those valves only let air out and none back in I run filter in case the valve fails. As far as sizes I'd guess they the same never owned or worked on 660 but same company built.
That's what we for bro
A simple generic small air filter, available at any auto parts store (usually found with their 'dress up' parts), works fine.
1 - 11 of 11 Posts
