1 - 2 of 2 Posts
Okay guys, I just replaced the head gasket and while I was there I put a 11.1 compression piston and a stage 1 hot cam and also put a cometics head gasket kit also sent the head to get pressure tested and cleaned out everything back together and it just won’t start. I have put new spark plug everything. It turns over but won’t start. I press the button and it keeps going and trying to start but it’s seems like it’s not getting enough of something to start. Idk if intake valves could be to tight or what it can be . But I have looked over it and kept trying and won’t start
So do all the normal things - check for spark, check compression, try starting fluid...
1 - 2 of 2 Posts
